搜索找到 2 个匹配
- 21 4月 2026, 15:54
- Jump to forum
- Jump to topic
Re: I make a tool to push the zpk format watchface into official simulator, but have little problems(Fixed)
I uploaded the polished version here:
https://github.com/Bob-YsPan/zepp-os-push-to-simulator-cs
https://i.postimg.cc/zG03y0Tf/cap2.png
Maybe this version is easier to merge into the Editor, it eliminates the dependency on Node.js.
Thank you so much for this excellent program!
It makes ...
- 21 4月 2026, 16:51
- Jump to forum
- Jump to topic
I successfully imported the dial I created in the editor into the simulator.
I honestly didn't understand the point of step 2 in your instructions. I just replaced the images in the dial file with standard PNG files and everything worked.
Since you’ve rewritten the code in C#, I should probably be ...
