La ricerca ha trovato 2 risultati
Return
da asoo
30 dic 2021, 01:32
Jump to forum
Jump to topic
Re: Is it possible to convert from GTS 2 to [GTS 3]?
as far as i know Now there is no GTS2 to GTS3 converter.
But you can use GTS2 resources to build GTS3 by use program "AmazFit WatchFace editor 2 for Windows" to unpack GTS2 and use unpack resources to build GTS3.
In the GTS3 build section, you can now You can register for the creation tool from ...
da shrewdroid
13 apr 2022, 08:37
Jump to forum
Jump to topic
Which tool is best to create watchfaces for Bip U/Pro?
hello members,
Can someone please tell me which is the best tool for creating watchfaces for Bip U/Pro ?
I have tried my hands on with AmazfitBipTools-1.0.3.1 , but the watch faces that are editable with this are not compatible with the watch.
And the ones which are compatible, I am not able to ...
