Пошук дав 1 результат
Return
peaceweapon
10 вересня 2019, 16:55
Jump to forum
Jump to topic
Re: Change vibration level?
If you set a very short vibration time (in the Notify and Fitness for Amazfit App you can write down the time in ms) it will be very soft and short.
Go to the Top row "settings" menu (the one with the sliders like in a music mix table) and then choose Tools in the second row.
Amazfit settings ...
