搜索找到 3 个匹配
Return
DxP
05 10月 2020, 11:46
Jump to forum
Jump to topic
[Tutorial] How to create WFZ watchfaces for Stratos 3 (new style / GTRWidget)
Hello community,
I've been asked several times how I do it with the watch faces and what software I use. The Software-question is easy to answer: Paint Shop Pro 2020 for the graphics, Notepad ++ for the code and 7zip to pack / unpack. Nothing else.
For the HOW-question - I sat down and wrote the ...
DxP
26 1月 2021, 06:05
Jump to forum
Jump to topic
Re: [Tutorial] How to create WFZ watchfaces for Stratos 3 (new style / GTRWidget)
As far as I can tell, the heart rate doesn't work with the AdditiveImages. I haven't managed to do that either, so I'm not using it. The ItemType "Arc" works with the heart rate. Maybe this will help you.
The SAWB only uses the original Huami widgets that also run on the Stratos 2 and the PACE ...
fcaronte
21 7月 2021, 19:04
Jump to forum
Jump to topic
mato 写了: 18 7月 2021, 17:40
I do not have legal Adobe PS, I use only free softwares, so it is no option for me :(
If you want use free software you can use "gimp" I was using together with Photoshop when I convert PNG to 8c and some time gimp get better results, give it a try!
