Pesquisa resultou em 10 ocorrências
Return
por Jackall Digital
24 Jul 2020, 23:10
Jump to forum
Jump to topic
Re: Decent Watch Faces for Mi Band 4
grishmabeli6 Everyone has different taste and needs.
I made a couple of watchfaces, they're mostly simple so the battery doesn't drain fast but I did try different things. My "Simply the Best" WF uses imagegoal (or goalimage I forgot) which displays an image when you reach the steps goal which I ...
por lvpokka
08 Jul 2019, 12:57
Jump to forum
Jump to topic
MiBandWFTool
Author
lvpokka
Tool Description
4. Mi band 5 supports 15,499,008 colors ...
por franluciani
19 Jul 2020, 02:25
Jump to forum
Jump to topic
Re: MiBandWFTool
Finally, it's done. I hope you like it
Imagem
por lvpokka
22 Jul 2020, 17:51
Jump to forum
Jump to topic
Re: MiBandWFTool
Beta test is closed for now... no feedback was received. Next version will be after new features will be discovered or bugs will be fixed
por lvpokka
31 Jul 2020, 21:26
Jump to forum
Jump to topic
Re: MiBandWFTool
Mi band 5 tool released from beta. Link added to topic :D
por Yife Playte
02 Ago 2020, 16:58
Jump to forum
Jump to topic
Re: MiBandWFTool
It's great to see the updated tools. but hey, could you please give me a sample json for band 5 which have all elements included? That'll be helpful.
por Pebbler
05 Ago 2020, 09:36
Jump to forum
Jump to topic
feedback on 2.1.4
Hi, have been using it since Mi Band 4, great tool!
Found some inconsistency between generated preview and real device display:
In PreviewStatesV2.1.4.json, when "Bluetooth" is set to false, Status.Bluetooth.ImageIndexOn is shown, and ImageIndexOff is shown when Bluetooth is true. I find it ...
por diopter
17 Ago 2020, 04:26
Jump to forum
Jump to topic
Re: MiBandWFTool
I can't get 2 small animations running at different speeds on the MI Band 5.
Both always run at the slower speed.
If I put both of them on the fast speed, they'll both run fast.
Is this a firmware bug or could it be that MiBandWFTool does not write the parameters correctly into the .bin file?
por diopter
17 Ago 2020, 17:43
Jump to forum
Jump to topic
Re: MiBandWFTool
There are no stock watchfaces with 2 different animation speeds.
Could you fix the "DelimiterImage" preview bug ?
Imagem Imagem
por lvpokka
06 Set 2020, 18:09
Jump to forum
Jump to topic
Re: MiBandWFTool
hi,
could u pls. modify a new tool based on the version of GTR-Watchface-editor,
The design is very convenient, intuitive, and has a “Shortcuts"
Do you have sourceCode of this program, i need real id of this Shortcut tag. Also need someone to test this element, because i dont want to brick my ...
