Se encontraron 5 coincidencias
Return
por Tolokali
15 Nov 2020, 12:56
Jump to forum
Jump to topic
problem installing faces the last 20 days
hi!
im owning a gts operating on an iphone 11pro max.
the last 2 weeks im having problems installing any watch face from the app as it tells me that i have to sychronize the watch with the Zepp app.
i have done everything(updates,reinstalling the watch) but still doesnt work.
any suggestions?
por alphaserver2
15 Nov 2020, 13:50
Jump to forum
Jump to topic
Re: problem installing faces the last 20 days
I have had exactly the same problem and cant find a solution
por ochackal
24 Ene 2021, 21:34
Jump to forum
Jump to topic
Aqui esse.problema começou agora depois de.atualizwr meu S10+ pro.android 11. Não consigo mais instalar as faces. O app não entende que já instalamos faces originais e não permite instalar as do app. Usando o bluetooth também da erro. Pede pra sincronizar com o zeep.
por Lorena1408
26 Ene 2021, 05:23
Jump to forum
Jump to topic
Tengo el mismo problema, cuando voy a instalar alguna face me dice que comprueba el estado de la conexion en zeep y esta todo ok. Alguna otra forma de hacerlo? Gracias
por ronaldoalvesbr
02 Feb 2021, 01:29
Jump to forum
Jump to topic
Não consigo instalar nenhuma Watch Face no GTS. Desde o último update do firmware do relógio. Espero que corrijam o quanto antes. Obrigado.
