Not very familiar with verge watchface.
Provide some technical information on stratos watchface.:
The function of raising hand to light up the screen does not support the display of background pattern on the dial.
normal watchface, not supported
The ...
Search found 2 matches
- 24 Mar 2019, 12:20
- Jump to forum
- Jump to topic
- 26 Mar 2019, 01:12
- Jump to forum
- Jump to topic
Re: Fabiobarbon Not Working for Verge.. HELP..!
Process examples:
1. Find a WFZ file of amazfit sports watch
2. Modify the suffix of ".wfz" to ".zip" in the file and extract it.
2. Modified version number
Open the "description. xml" file and modify the code:
Amend < version > 1.2 </version > to < version > 1.6 </version >
Low version ...
Low version ...
