Page 1 of 3
If you find any bug in the use of AMAZFIT verge lite, please leave a comment here [Verge Lite]
Posted: 07 Nov 2019, 03:17
by 侯侯大神
Mainly in the use of bugs, preferably not recommendations.
they have their own planning arrangements, and may not be arranged.
If it's a bug they'll fix it ahead of time
Re: If you find any bug in the use of AMAZFIT verge lite, please leave a comment here
Posted: 07 Nov 2019, 03:22
by 侯侯大神
Posted: 08 Nov 2019, 02:44
by 侯侯大神
I will add Suggestions on the last line of feedback after that, so that they can see.
Such as AOD
- Notes_20191108_102748.png (1.77 MiB) Viewed 33616 times
Posted: 09 Nov 2019, 07:23
by 侯侯大神
Notice slip has some problems and has been fed back
- Notes_20191109_110504.png (2.38 MiB) Viewed 33487 times
Posted: 12 Nov 2019, 05:23
by afwafwafw
I think this is not bug, but another requests.
Support for center position of analog hands(GTR works)
Support for some status icons(bluetooth, lock like GTR)
Support for weather info(GTR got it from recent firmware)
Posted: 12 Nov 2019, 14:59
by Edson78
My Verge Lite has just updated to version 1.3.4.06. I still can't verify what has changed.
Posted: 13 Nov 2019, 02:51
by 侯侯大神
afwafwafw wrote: 12 Nov 2019, 05:23
I've given them feedback in a variety of ways, and in most cases the engineers don't respond.
- Screenshot_2019-11-13-09-51-39-227_有道翻译官.png (188.22 KiB) Viewed 33442 times
Posted: 13 Nov 2019, 04:03
by 侯侯大神
The new firmware adds bugs from previous versions and has been reported.
v1.3.2
Countdown time will not automatically light the screen
v1.3.3.16
- fixed an issue where countdown time would not automatically light up
v1.3.4.06
The countdown time will not automatically light the screen problem recurrence
Posted: 13 Nov 2019, 04:46
by afwafwafw
侯侯大神 wrote: 13 Nov 2019, 02:51
I've given them feedback in a variety of ways, and in most cases the engineers don't respond.Screenshot_2019-11-13-09-51-39-227_有道翻译官.png
So sad but it's a little bit promising for release of a new firmware.
Posted: 14 Nov 2019, 04:16
by Domenick
Bugs:
1) resetting auto brightness when the flashlight is turned on
2) Disabling alarms when turning on / off the dnd mode manually
3) Support wather widget in Watchfaces
Posted: 15 Nov 2019, 01:49
by afwafwafw
I've found out status icons bug was gone without notice while I'm packing new WF.
It was there at the first firmware(v1.3.2?), and not at (v1.3.4.06).
I cannot confirm when it was fixed.
Anyway, surprise, surprise.
I'll check for center position bug again. It's still in there.
Posted: 29 Nov 2019, 09:17
by afwafwafw
It's very strange but today I've found out center position of analog hands works.
Still don't know when they fixed it.
So only thing left for me is weather support!
Posted: 30 Dec 2019, 14:34
by tasse
Hello.
I am having problems with my Verge Lite, during outdoor running, after 2-3 kilometers, the watch restarts alone and doesn't record the activity. Although the steps are recorded.
I did a factory reset but I still have the same problem.
My current firmware version is V1.3.4.06
Do you have any solution for this problem?
Does anyone else encountered this problem?
Posted: 03 Jan 2020, 20:31
by tasse
I solved the problem by downgrading the firmware to v1.3.2.00 and using only Notify & Fitness app
If I'm using Mi Fit will automically update the firmware
Posted: 17 Jan 2020, 15:26
by SigmaLambda
Also on V1.3.4.06. Experiencing randon reboots. Also random power offs. The watch doesn't restart itself, it just shuts down and I have to manually turn it on again.
Happened several times since the update (mostly while walking/running using the gps, so the activity data was lost) but also during normal operation while doing office work.
Posted: 27 Feb 2020, 05:56
by Hobbitka
Same restarting issue here!
Firmware: 1.3.4.06
My watch restarting during the day also! It's super disturbing! I've used it only for one outside running activity and it turned off in that situation too.
Posted: 27 Feb 2020, 05:57
by Hobbitka
tasse wrote: 03 Jan 2020, 20:31
Can you help me how to downgrade?
Where to find older firmware and install it on the watch?
Posted: 13 May 2020, 23:06
by mmtctn
my amazfit verge lite watch connected to the iphone turns off by itself please help
Posted: 19 May 2020, 18:50
by Emert20
Friends amazfit verge lite reached my hand, but when I wake up the screen by rotating my arm, there is another enlightenment at the bottom which takes a very short time before the watch face comes. I recorded from the phone in slow motion. Something like this happens when the screen of the watch is off for 3 to 4 minutes or more. This does not happen when the screen wakes up shortly after waking up. Is this the same for everyone or is there a problem on my device?
The whiteness I mentioned is just before the screen wakes. You can access the video by deleting the space between dot and com
https://drive.google.com/file/d/1gITB7K ... drive_open
Posted: 29 May 2020, 02:38
by Jizend
The problem is my watch keep restarting when i do outdoor running and sometimes when i didnt do anything.. i mean when i just put my watch in my wrist then suddenly it restarting.. i try to unpair and pair it again but it didnt work.. please help me..
Posted: 29 May 2020, 12:09
by taw_bip
Jizend wrote: 29 May 2020, 02:38
Did you try a factory reset?
Posted: 16 Jun 2020, 18:46
by Saatmanyak
the bug is still present.
when i running it shuts down automaticlly after 10 minute and doesnnt record it
how can i solve it
Posted: 08 Jul 2020, 20:13
by tasse
You cannot solve it, it's obviously a software bug.
I did several reports and contacted the amazfit support in January but they didn't gave a shit about the bugs since they didn't do anything until now.
Personally I regret that I bought this watch, I don't use it anymore since February. I already moved to Garmin and most probably I will never buy any amazfit products
Posted: 10 Jul 2020, 07:52
by PauloprAmigo
Hi
I have the some problem with my amazfit Verge Lite. It restart during the outdoor runnig.
There is a solution?
Posted: 10 Jul 2020, 13:25
by PauloprAmigo
I have the some problem.
Saatmanyak wrote: 16 Jun 2020, 18:46
how can i solve it
