Page 1 of 2
Anything for Amazfit GTS?
Posted: 23 Oct 2019, 18:35
by Show
Hi there , looking for any tool for custom watchface for GTS . Even beeing able to set my own background with time/step counter will be huge.
Re: Anything for Amazfit GTS?
Posted: 24 Oct 2019, 18:32
by eprom
+1
Posted: 25 Oct 2019, 07:05
by hirow
is it posible to make our own whatchfaces???
Posted: 25 Oct 2019, 13:15
by Hanuman69
+1
Posted: 27 Oct 2019, 16:34
by netoper
this is joke. i cancel order for gts. dont want them. watches in this price category have normal development environment and not this. watchfaces are more than primitive images. for bip is ok. cost few dollars. but for 160+ dolars watch is this unacceptable. and now huami have conquest for watchface creators and they don't give them anything. :D probally this conquest is not about WF myself but who code for free some utility :D
Posted: 30 Oct 2019, 14:36
by Biggie
Again, is there any tool for unpacking/packing watchfaces? The material from Huami's creaqtive contest contains pictures and keywords only, no file structure, no syntax, and most notably: NO TOOLS.. useless at present!
Posted: 30 Oct 2019, 23:09
by dpassaggio
For unpack and repack watchfaces, the utility for GTR works, but we have noting for install them on the Gts
Posted: 31 Oct 2019, 11:50
by Biggie
Thanks! Will give this a try...
Uploading to the watch can be do with the app "Notify & Fitness". There is a little issue: The function to load .bin file can load the WF, can sync it to watch, but shows no preview...
(Have this tested with the black cat by "zichuanxiu". Dowloaded the *.bin file, renamed it, and synced this file to GTS)
Posted: 31 Oct 2019, 14:46
by Biggie
@depassaggio
Which tool do you have to use? I tried the 'AmazTools v0.1.0.13' (with GTR cmd), as well as the 'py amazfit tool'. Nothing will be unpack. On the py tool the log says 'Reader' object has no attribute '_parameters', then it breaks. It seems if the syntax for GTR and GTE is not the same...
Posted: 04 Nov 2019, 11:15
by dpassaggio
Biggie wrote: 31 Oct 2019, 14:46
@depassaggio
to make it work, you need to rename the ".bin" file to "GTR.bin" ,obviously the file must be in the same folder as the executable
Posted: 04 Nov 2019, 21:13
by Biggie
Yes, so I have it tested! Renaming is not enogh, because in the command Unpack(GTR-xxmm).cmd the size of the face is contained. But even this I have tested , also with -size348 (the GTS width), -size442 (the GTS height), and just with -width348 - height442.
Errormessage: System.ArgumentOutOfRangeException: Der Index lag außerhalb des Bereichs. Er darf nicht negativ und kleiner als die Sammlung sein. (Index out of range. Could not be negative or less than collection."
Posted: 05 Nov 2019, 15:11
by KoltesPunti
dpassaggio wrote: 04 Nov 2019, 11:15
@depassaggio
This doesnt work - i can only unpack 1 Watchface from the GTS but the Repack doesnt work properly! So without a tool we cant make watchfaces till now!
[mention]Biggie[/mention] hab schon so einiges versucht aber es funktioniert nicht solange die programme nicht angepasst werden! Glaube es macht auch nicht viel sinn herumzuprobieren! Der Chinese mit den 2 upgeloadeten Watchfaces könnte uns vielleicht weiterhelfen!
Posted: 06 Nov 2019, 09:45
by dpassaggio
obviously I always said from the first post, with the procedure called before the gtr, for now we can only unpack, we need to find a system to re-compact, eliminating the error of centering the hands
Posted: 19 Nov 2019, 14:28
by ionut02
Any news regarding custom watchfaces, I've just upgraded from the Amazfit Bip to Amazfit GTS on a black Friday promotion. I'm looking for a way to remake 3 of my watchfaces for the GTS, I've gotten used to them and would love to see them on the OLED display.
Posted: 19 Nov 2019, 19:36
by KoltesPunti
Nothing new, there‘s a tool from chinese people but no one knows how to repack the files!
Posted: 20 Nov 2019, 04:54
by dpassaggio
take a look here; it's a start, I followed the whole procedure but I still can't load them on the device; for those with android it should go
https://www.bandbbs.cn/threads/1144/
Posted: 20 Nov 2019, 08:02
by Buoncuo
dpassaggio wrote: 20 Nov 2019, 04:54
it doesn't create a .bin file, only a zip that will be imported in an android app with donations
Posted: 20 Nov 2019, 15:29
by ionut02
Someone just posted a custom watchface for GTS, .bin but now is gone from the catalog. I've installed it and worked OK on my GTS. The preview when quick selecting a new wathcface - when you long press, seems to be for the simple analog with red indicators on black background. So there is a way to edit and pack files.
Posted: 20 Nov 2019, 16:17
by dpassaggio
ionut02 wrote: 20 Nov 2019, 15:29
I had loaded the diesel style custom dial, the files can be converted to .bin with the Chinese procedure; could you explain to us how did you install it on the GTS? I didn't succeed. thanks
Posted: 20 Nov 2019, 17:01
by ionut02
Using Amazfit Tools, latest version, 4.6.2 open app, from left side menu select Watch Faces, then on the right side select the Settings option, gear icon, and then from that menu select Install Custom. Then just select your bin file and wait for it to finish. Here is a photo of that watch face on my GTS https://photos.app.goo.gl/99mxj6wBUXsjteXU7
Posted: 21 Nov 2019, 14:10
by Kamaal
dpassaggio wrote: 20 Nov 2019, 16:17
Sorry, can you share the "Chinese procedure"?
Posted: 24 Nov 2019, 11:23
by dpassaggio
ionut02 wrote: 20 Nov 2019, 17:01
you have the apk "Watchfaces & Amazfit"? you can share it?
Posted: 24 Nov 2019, 11:24
by dpassaggio
Kamaal wrote: 21 Nov 2019, 14:10
as soon as I can close all the working procedure, I agree with it
Posted: 24 Nov 2019, 22:26
by juanchurry
[quote=ionut02 post_id=3560 time=1574269319 user_id=9993]
donde puedo descargar la aplicacion amazfit tools?has creado tu alguna esfera para gts?
Posted: 25 Nov 2019, 04:55
by ionut02
No, dpassaggio posted a test watch face for the GTS. I've just tested it, and posted a photo of it on my watch. We are still waiting for a method to be available for creating watch faces. If you feel lucky you can test the chinese platform mentioned on the first page of this topic, but they are requesting donations to download.
