Page 1 of 1
Battery drain [GTR]
Posted: 13 Oct 2019, 10:22
by Carlospaco
I have my gtr now for a week, and my battery drains in 30 min.
When i wanted to charge it fot the first time, its charge in less then 30 min full.
There is a youtube movie, off someone thats have the same problem.
Is there here someone also?
I am desperate.
Thanks in advanced
Re: Battery drain
Posted: 23 Jan 2020, 06:51
by Born2run
I do not know if your issue is solved but I had similar problem. My battery used to drain about 6% per day which gave like 2 weeks of battery life instead of suggested 24 days. Not a huge problem like yours but still. Well last week I read that this battery should be formatted first and its good to keep the watch plugged to the charger additional hour after it reaches 100%. On the same day a new firmware update was released. I did the longer charing and now, 5 days later, my battery status is 93%! I do not know if the new firmware helped as well, but who knows... I hope it will help you.
Re: Battery drain
Posted: 02 Jun 2020, 00:29
by Brunobomber
my gtr 47 lasts only 5 days....even if i turn off everything you can imagine, turn off phone bluetooth already to be sure it is not communicating with clock...nothing...same 5 days....new firmware instaled today (1.3.5.72)...lets see if if gets better (dont think so, unfortunatelly)...see many people with same problem...i'm from brazil...
Re: Battery drain
Posted: 02 Jun 2020, 07:19
by Lordalpine
Carlospaco wrote: 13 Oct 2019, 10:22
I am desperate.
Thanks in advanced
Hi^^ No way... impossible in 30 minute to discharge or charge. It takes 1H30 // 2 H to charge normally with a 5V 1Amp wall charger to charge it.
Your battery isn't calibrated or dead battery [ Main problem for GTR made before December 2019 ]
The best way to resolve your problem is :
Firmware update
Hard reset // Factory reset
Charge it with a 1amp // 1.5amp 5v wall charger
Let it charge to 100% and @ 100%, don't unplug it let it alone charging for an extra 2 hour time.
Don't let the battery die... @ 20 / 25% Charge it and repeat the first process
Always charge it with a wall charger 1Amp // 1.5 amp 5V.... the battey is a small battery, if you have an old "branded" wall charger for a old phone [ like samsung it's perfect ] Sure you have one somewhere in your house.
* and avoid fast charger over 2amp or USB charge [ Fast charger or USB charge plugged to a PC // USB Hub is avoid on my side, it's personal choice ]
Re: Battery drain
Posted: 25 Dec 2020, 05:25
by NikiWafa
I also have a problem with the battery, my problem arises when updating the Zepp, my battery from 100% lasts only in 3 days, whereas previously it could be up to a week on a single charge
(sorry if my language is messed up, because I use google translate)
