Page 1 of 5
How to install watchfaces (Bip, Verge Lite, GTR, GTS, T-Rex, Cor, Mi Band 4)
Posted: 05 Aug 2019, 19:49
by GIK-Team
Detailed instructions for installing custom watch faces on Amazfit GTR, GTS, T-Rex, Verge Lite, Amazfit Bip smartwatches, and Cor and Mi Band 4 smart bracelets.
Note! At the moment, the instruction is relevant only for Zepp (Amazfit)
For a successful installation, you need to connect your gadget to a smartphone on Android or IOS with the Amazfit (Zepp) app installed. You also need to have installed file manager and pre-download the watch face that you would like to set on your watch.
Installation for Android
  1. First, you need to install one of the stock watch faces available in Zepp (Amazfit)/Mifit (if you have already installed one, you may skip this step).
  2. Open the folder with the downloaded watch face in the file manager with the path:
    • Zepp (Amazfit) /Android/data/com.huami.watch.hmwatchmanager/files/watch_skin_local/
    • Mi Fit /Android/data/com.xiaomi.hm.health/files/watch_skin_local/
  3. Go to any of these folders and find the .bin file. Copy the .bin file name.
    • Name example for bin: 4lIYUjzg3Vwqt8tJU9sYLeOSqUSAreJNzUxJhxgM.bin
    • Name example for zip: UQkNrGEQmaPvYbLmGseWkOkUCHDDkOBf.zip
  4. Go to the custom watch face and rename it using the name of the standard watch face.
  5. Copy the watch face file with the new name and transfer it to the folder from step 3 with a replacement.
  6. Open the Zepp (Amazfit)/Mifit app and install the stock watch face, which file you replaced.
Android apps
AmazFaces app
Gadgetbridge (Android)
Notify & Fitness for Amazfit (Android)
Amazfit Replacer (Android)
Installation for iOS
You may also use our application or other, such as AmazTools (iOS), to install watch faces
This manual is current at the time of writing.
If you notice any inaccuracies or mistakes, please, let us know.
Re: How to install watchfaces (Bip, Verge Lite, GTR, GTS, T-Rex, Cor, Mi Band 4)
Posted: 01 Aug 2020, 13:06
by GIK-Team
Another way to install from urieleugenio (Mi Band 4 / Mi Band 5)
urieleugenio wrote:
I use a PC and Android phone, not just the phone.
In the store WF folders there are 3 files: a BIN file, an infos.xml file, and an image file (watchface preview).
I copy these files to my PC (using OneDrive or data cable).
The infos.xml file contains the WF name. You can right-click and select edit to open the file with WordPad.
Just put the desired WF name by changing the name (marked in bold and underlined below). Then replace the file in the phone folder.
<?xml version='1.0' encoding='utf-8' standalone='yes' ?><watch_skin_info><info>{"O00000oO":"NAME","O00000oo":0,"O0000O0o":102382,"O0000OOo":0,"O0000Oo":false}</info></watch_skin_info>
To change the preview image, erase the existing image and place in the folder a PNG image.
Image file name is not importante.
I only tested thin on Mi Band 4 and 5.
Posted: 06 Oct 2020, 08:50
by Selects
Does not work for GTS 2
Posted: 06 Oct 2020, 09:17
by GIK-Team
Selects wrote: 06 Oct 2020, 08:50
We don't have any information yet :(
Posted: 10 Oct 2020, 19:44
by miaoweidis
GIK-Team wrote: 06 Oct 2020, 09:17
It also don't work at GTR 2
Posted: 10 Oct 2020, 20:41
by GIK-Team
miaoweidis wrote: 10 Oct 2020, 19:44
We will publish the information as soon as we have it.
Posted: 04 Nov 2020, 05:18
by Godfatheroftech
Looking forward to some GTS 2 faces
Posted: 19 Nov 2020, 20:28
by Ecemen
Hello! I managed to change watch face at Amazfit Verge Lite but It always change the 3rd watch. How can I change the 1st or second one? Or can I add these watch faces to Mi Fit Library or Zepp library ?
Posted: 19 Nov 2020, 21:40
by GIK-Team
Ecemen wrote: 19 Nov 2020, 20:28
No, only the third one can be replaced.
Posted: 03 Dec 2020, 09:36
by saloca
Hola alguien me puede decir como se apaga el amazfit x, y como se puede ver en el ordenador para cambiar esferas. Gracias
Posted: 13 Dec 2020, 20:19
by Pj27305222
Is it possible to somehow change the icons on the zepp "online watch faces". I've followed the steps in this tutorial but the icons from the app itself doesn't change and therefore I don't know which one i've changed.
Does this make sense?
I'll try to explain further. I've followed these steps:
  • 1. First, you need to install one of the stock watch faces available in Amazfit/Mifit (if you have already installed one, you may skip this step).
  • 2. Open the folder with the downloaded watch face in the file manager with the path:
    Amazfit /Android/data/com.huami.watch.hmwatchmanager/files/watch_skin_local/
  • 3. Go to any of these folders and find the .bin file. Copy the .bin file name.
    Name example: 4lIYUjzg3Vwqt8tJU9sYLeOSqUSAreJNzUxJhxgM.bin
  • 4. Go to the custom watch face and rename it using the name of the standard watch face.
  • 5. Copy the watch face file with the new name and transfer it to the folder from step 3 with a replacement.
  • 6. Open the Amazfit/Mifit app and install the stock watch face, which file you replaced.
Now when I open the Zepp app, under the 'Online watch faces' It still shows the old icon, even though when I sync it shows the new watchface.
If I've changed multiple watchfaces it's hard for me to remember which stock face i've changed, does it makes sense?
I've tried replacing the .png file in my android folder (the same place where I place the .bin file, but it doesn't show in app and also it replaces with the stock in the app).
Does anywone have a trick how to see which one i've changed or a walkaround to this ?
Please help
Posted: 05 Jan 2021, 02:56
by tyrfing15
Does not work for BIP U PRO
Posted: 05 Jan 2021, 10:45
by GIK-Team
tyrfing15 wrote: 05 Jan 2021, 02:56
Of course, they don't even have custom watchfaces yet.
Posted: 09 Jan 2021, 08:39
by zaky_hr
iOS 14.3 there is no more amazfit folder in file manager. Do you have a solution for that?
I use iPhone 11 pro and i was always changes the face of my gts. Now not any more :(
Posted: 09 Jan 2021, 12:27
by GIK-Team
zaky_hr wrote: 09 Jan 2021, 08:39
https://itunes.apple.com/us/app/amaztoo ... 33880?mt=8
Posted: 09 Jan 2021, 14:49
by brockdisciple
FOR IPHONE WITH ZEPP:
I couldn't connect to my GTR from the AmazFaces app. So I did this and it worked
Download AmazTools
Download your watch face from AmazFaces
Click on the box with the arrow to send the file
Choose Amaztools
Then install the file :) EASY
Posted: 12 Jan 2021, 11:31
by jkilwatch
Hola, no paro de buscar en todos lados y no encuentro nada... y me resulta raro... Estoy buscando la manera de poder instalar nuevas faces para mi Amazfit bip U pero no encuentro nada alguien me puede ayudar se agradece.
Posted: 14 Jan 2021, 12:49
by dacbrunete
It is impossible to install watchfaces on GTR2 with an iphone, neither with the zeep app, nor with the amazfitwatchfaces app, nor with amaztools, any ideas?
Es imposible instalar watchfaces en GTR2 con un iphone, ni con la app zeep, ni con la de amazfitwatchfaces, ni con amaztools, ¿alguna idea?
Posted: 18 Jan 2021, 03:04
by JC007
Hello
Inside Android 11 you don't have access to the / Android / data / folder
How you do that ?
Posted: 18 Jan 2021, 14:45
by GIK-Team
JC007 wrote: 18 Jan 2021, 03:04
Hello
How you do that ?
We are preparing an update for our application
Posted: 03 Feb 2021, 12:50
by Fraxinum
dacbrunete wrote: 14 Jan 2021, 12:49
It´s true, with my iPhone 6 i can´t install any watch faces in my GTR2, i tested it with Amazfitwatchfaces, Amaztools, and nothing.
Posted: 12 Feb 2021, 04:01
by Oblueeyes26
I'm having problems with instructions on the downloads. It ask open in different app but only gives choice on a painting app. The other about it is flip it. It doesn't show the app I need
Posted: 14 Feb 2021, 10:36
by yusry1993
I dont have file watch_skin_local. Plss help
Posted: 14 Feb 2021, 12:43
by GIK-Team
yusry1993 wrote: 14 Feb 2021, 10:36
https://www.youtube.com/watch?v=VzlsqHQJSic
Posted: 03 Mar 2021, 00:44
by Jasonzye
How can i replace the faces?? The tools said Please keep Zepp in background?This is IOS 14
