Pagina 1 di 1
Help adding date / removing steps to this theme
Inviato: 13 lug 2019, 13:29
da sirvictor93
I'm working on this watchface
/mi-band-4/view/938
based on /mi-band-4/view/821 by user Swift. inspired from Sony SmartWatch 3
My mods:
- hours and minutes of the same thickness to improve readability,
- the battery icon has been replaced with the "%" symbol and when is under 10% a red dot appears next to it.
- The step line has been covered with blacks images.
Can someone please help me add a minimal date under the hour and maybe remove the step-count line (that i've covered in black) for saving simensions?
Thanks to everyone, I have 0 coding skills :(
Re: Help adding date / removing steps to this theme
Inviato: 14 lug 2019, 08:31
da yzx_28
hello I think I can help you.
You need to open your JSON file.
Then change the corresponding code.
Such as you said you want change hour and minutes
You can find them in your json file
Do you see the Minutes term?
Yes, that's what you need to change
You can change their coordinates by changing x and y
You say you want to delete steps
You can remove Steps by deleting activity-> Steps
You can delete the step image by deleting StepsProgress
Another thing I want to remind you of is the json format especially the ","
I always make formatting mistakes and can't wrap
I am a Chinese
My English is not so good
So I used Google translate
