Page 1 of 1
How to install watchfaces (Mi Band 4)
Posted: 03 Jul 2019, 11:12
by osmat
Installing the Watch faces via AmazFaces app:
Installation requires:
MiFit
File manager
Download the dial that you want to replace. You can download them in the themes Dials for Xiaomi Mi Band 4, as well as with any third-party application or do it yourself (on order).
The dial should have the extension * .bin (if the file is in the ZIP archive, then unpack)
Install the MiFit application.
On the phone include internet, Bluetooth and GPS.
Launch MiFit and install any dial available.
Open the watch_skin_local folder in the file manager along the
 Android / data / com.xiaomi.hm.health / files /
path, which will contain the downloaded dial of the 4lIYUjzg3Vwqt8tJU9sYLeOSqUSAreJNzUxJhxgM.bin type
Copy the name of this file, delete the file and rename your dial with this name.
Copy to your watch_skin_local folder your renamed dial
Go back to MiFit and apply the same dial.
Animated watch face
You can use "watch skin local" (Local watch Face) in Mi Fit to update or change your watch face.
But you must edit some bytes in the animated watch face .BIN file In order to make that .bin file can be displayed in "watch skin local"
How to HEX your .BIN to use in "watch skin local" of Mi Fit
1. Open your .BIN with HexEdit https://www.dropbox.com/s/hmqdynh8dl0lj ... t.zip?dl=0
2. On bytes 17 to 24 edit FF FF FF FF FF FF FF FF to 24 00 d0 03 00 00 3d 78 and save
3. Now you .BIN can use in "watch skin local" of Mi Fit
How to use "watch skin local" ( Local watch Face )
1. Folder of "watch_skin_local" is /storage/emulated/0/Android/data/com.xiaomi.hm.health/files/watch_skin_local/
2. make new folder in "watch_skin_local" (one folder for one watch face)
3. Copy modified youreWatchface.BIN and yourWatchface.jpg or png or gif in your new folder
4. Now open Mi fit and go to "Local watch Face" you can see your Watcface
Small program for patch file.bin on bytes 17 to 24 edit FF FF FF FF FF FF FF FF to 24 00 d0 03 00 00 3d 78 ( for PC )
Mi Band4 patch.zip
(738.96 KiB) Downloaded 1298 times
Author: [mention]romstemp[/mention]
Can I install a custom firmware / resource / font / Watch faces from iOS?
  • Of course! Just open them with AmazTools!
AmazTools
https://itunes.apple.com/us/app/amaztoo ... 33880?mt=8
How to on iOS
