Pagina 1 di 1
How to make/edit watchfaces?
Inviato: 03 apr 2018, 11:43
da baxxcipo
How we can make or edit watchfaces? would be very nice to know.
Re: How to make/edit watchfaces?
Inviato: 03 apr 2018, 13:43
da Lukass
Unfortunately, there is as yet no such possibility
Inviato: 29 apr 2018, 04:35
da zsoltee69
Please editor
Inviato: 30 apr 2018, 18:32
da osmat
Inviato: 01 mag 2018, 05:05
da zsoltee69
osmat ha scritto: 30 apr 2018, 18:32
THNX
Inviato: 02 mag 2018, 07:32
da osmat
zsoltee69 ha scritto: 01 mag 2018, 05:05
THNX
https://amazfitwatchfaces.com/editor/wa ... ditor/?cor
Inviato: 06 mag 2018, 21:36
da bui
Does anyone have a detailed guide for creating watch-face? I do not understand how to insert the months and days of the week in letters.
Inviato: 08 mag 2018, 06:42
da LostEchoes
Guys are we supposed to run the Watchface.exe file on Windows ?
I download "AmazfitCorTools-1.0.0.1" and I unzip it to my desktop.
My goal is to edit a .bin file according to the instructions ("Disassemble .bin file with AmazfitBipTools (AmazfitCorTools for Cor), click on Select images and select them from watchface folder by Ctrl+A, then select JSON file by clicking on JSON Select. After that you can set numbers to display by clicking Settings or edit the watchface").
When I run the watchface.exe I get a screen for one second and then everything closes.
EDIT: Ok I found the way to extract the .bin contents, by dragging the .bin file on the .exe file.
Then I get into the watchface online editor, I choose / edit the settings I want.
The last step is to create the new .bin with the new edited files (images and .json file).
I still haven't found how to do this.
Inviato: 09 mag 2018, 08:56
da Alexam
LostEchoes ha scritto: 08 mag 2018, 06:42
I have the same problem
Inviato: 12 mag 2018, 00:04
da imn
To create the new .bin file, dragging only the .json file on the .exe file. Is important have the images and the .json in the same folder.
After this step, you have the new .bin in the same folder of the images and the .json file.
Besides, you have a new .gif with the preview of the new design in the same folder.
You have more info in the first step of this guide:
https://forum.xda-developers.com/smartw ... s-t3746967
I hope it helps you.
