Page 1 of 1
Wheater-Icon too big on Amazfit Band 2 (Cor 2)
Posted: 18 May 2019, 20:30
by chb
on old Amazfit Cor 1 it works...
Anyboda here with the same problem? Or better: Do you have a solution?
(I don't wanna edit the WF with Editor - takes to much time ;) )
Re: Wheater-Icon too big on Amazfit Band 2 (Cor 2)
Posted: 22 May 2019, 08:07
by osmat
Attach a link to this dial, we will fix it for you
Posted: 23 May 2019, 15:31
by chb
Posted: 24 May 2019, 08:52
by osmat
The problem is that they all take the weather icons from the firmware resources.
Posted: 24 May 2019, 08:53
by osmat
I did not find official data about the resolution of the screen on Cor 2
Posted: 24 May 2019, 09:01
by osmat
To solve this problem, weather icons need to be added to file watchface and also add the appropriate code to .json
"Weather": {
"Icon": {
"CustomIcon": {
"X": 133, position
"Y": 20,
"ImageIndex": 38, name first
"ImagesCount": 26
Posted: 24 May 2019, 09:30
by TXK
Posted: 24 May 2019, 09:38
by osmat
https://amazfitwatchfaces.com/cor/view/886
check everything should be fine
