Сторінка 1 з 1
Is it possible to have heart rate icons?
Додано: 09 квітня 2019, 15:09
djeaton
Where is the best place to get help with advanced watch face creation? I'm particularly interested in learning how to use the images that seem to have multiple images in the same PNG file. My hope is to use something like that to create a colored icon for pulse rate instead of numbers. My goal is to make a heart on a black background and the color of the heart changes based on the pulse range with the background changing if pulse goes above 100. I want to ignore the digits and go with an image for the 10's and anything over 100. So anything over 80 would be one color, anything over 90 a different color, anything over 100 would change the background of the image, and so forth.
Anyone seen anything like this before? Anyone know if it is possible or how?
Re: Is it possible to have heart rate icons?
Додано: 09 квітня 2019, 16:00
Pdasnews
Yes you can. Check my watchface for help, delete numbers and put heart instead of chrono.
I can't link the watchface. Search for " Samsung gear sport edit "
Додано: 09 квітня 2019, 17:38
Додано: 09 квітня 2019, 23:28
djeaton
What I don't understand is images like 00022.png in your zip file and the -482 spacing in the json file. I haven't found any information on these graphics that have multiple pieces in them. What I'd ultimately like to do is have no numbers at all, just the icon, and have icons for under 70, the 70s, 80s, 90s, 100s, 110s, 120s, and so forth up to 160s. So ten different graphics minimum, and 12 if I figure out how. If not, just triggering off of the "tens" number would likely work. But since I don't understand these images that appear indexed or something, I'm not sure exactly how to proceed.
Додано: 10 квітня 2019, 02:12
That watch face is not mine, I just solved the picture according to my understand.
However, what I understand is as follows. ( Please see the picture below )
It's just my understanding. I'm not sure if it's 100% accurate or not.
Додано: 10 квітня 2019, 12:03
djeaton
Thanks. I'm going to study that and see if I can't figure it out!
Sure wish Amazfit would put out a comprehensive guide to this kind of stuff. Or, better yet, give us "ones", "tens" and "hundreds" capabilities for all of the numbers and not just hours and minutes.
Додано: 10 квітня 2019, 12:15
djeaton
BTW, what editor are you using that is displaying the spacing information in the image above? I've been using that online tool, and it doesn't look like that. Since you are the watch face expert, are you using a better/different tool?
Додано: 10 квітня 2019, 14:27
djeaton писав: 10 квітня 2019, 12:15
Bip WF Editor by ilGruppoTester
https://www.mediafire.com/folder/3o37ts ... r_-_Stable
AmazfitBipTools
https://bitbucket.org/valeronm/amazfitb ... downloads/
Додано: 12 квітня 2019, 11:20
TXK
asoo писав: 10 квітня 2019, 14:27
Unable to decompress after downloading. The compressed package file is damaged. My question??
Is there anyone who will help me?
Додано: 12 квітня 2019, 14:26
TXK писав: 12 квітня 2019, 11:20
Which file do you have issue about decompress?
Bip WF Editor by ilGruppoTester ?
AmazfitBipTools ?
But I downloaded all and test decompress . it's can do 100% no error
AmazfitBipTools
ps. Decompress with winrar 5.70
Додано: 13 квітня 2019, 02:26
TXK
asoo писав: 12 квітня 2019, 14:26
AmazfitBipTools ?
AmazfitBipTools
I get it. my winrar is 4.11. so......
thank you
