Pagina 1 di 1
Request watchface for T-Rex 3 pro 44mm
Inviato: 12 lug 2026, 12:31
da yasuu
Hello, can you please create a watchface for me ?
I'm specifically looking for Hybridcharge & PAI in my watchface which isn't available anywhere.
I'm also attaching a reference of the watchface, if anyone can create the same please.
Re: Request watchface for T-Rex 3 pro 44mm
Inviato: 12 lug 2026, 18:35
da asoo
yasuu ha scritto: 12 lug 2026, 12:31
And please
do not give credit to me
Inviato: 14 lug 2026, 07:16
da yasuu
Yes, thanks so much Asoo, let me try this on my watch see if all the shortcuts work, thanks so much
Inviato: 14 lug 2026, 08:24
da yasuu
It does work very well on my device, the shortcuts work, also the size of some numbers are bit out of the box, it's not much noticeable.
Can you also tell me if the altitude and air pressure increases, will the number in the box fit ? let's say the altitude reaches 5535m and air pressure is 1069hpa, how will it look in the box ? Because there are only three digits in the watchface for now. Please respond.
Inviato: 14 lug 2026, 14:26
da asoo
yasuu ha scritto: 14 lug 2026, 08:24
I've already mentioned that
"This dial has some elements that are different from the original."
If you want it to be exactly like the image you sent, you need to send all the resources for that watchface . If you only have a sample image, I think the watch face I've made should be sufficient for use.
I cannot answer your question because I do not have a T-Rex 3 Pro 44mm. If you want to verify its authenticity, you need to perform the verification on your own device.
And if you want to modify it to your needs, you can use the sashaCX75 Editor to do so yourself.
(Watch face editor for Amazfit watch on ZeppOS)
This is an example image displayed in the editor.
