Page 1 of 1
Request for Seiko Full Metal Alchemist Watchface [Balance 2]
Posted: 27 Jun 2026, 16:11
by LawDads
Hi!
Is it possible to convert this watchface from GTR3 to Active 2? Or can I use the same watchface link?
viewtopic.php?p=22400&hilit=full+metal+alchemist#p22400
Thanks a ton in advance!
Re: Request for Seiko Full Metal Alchemist Watchface [Balance 2]
Posted: 27 Jun 2026, 16:36
by asoo
LawDads wrote: 27 Jun 2026, 16:11
Hi!
You can use GTR 3 with Active 2, but the screen won't fit because GTR3 has a resolution of 454x454, while Active 2 has a resolution of 466x466. Therefore, if you want it to fit, you need to convert it to Active 2.
You can use sashaCX75's editing program to convert it.
This is an example obtained from conversion using sashaCX75's program.
R1_SEIKO_YGTR_3_Active_2.zip
(290.17 KiB) Downloaded 12 times
R1_SEIKO_GTR_3_Active_2.zip
(291.48 KiB) Downloaded 12 times
Posted: 27 Jun 2026, 16:52
by LawDads
This is noted, thanks so much for the quick response and help!
