Page 1 of 1
T-Rex 3 pro 48mm
Posted: 01 Apr 2026, 03:43
by Onefunkysn
I am looking for someone who can create a watch face for me. I am looking for a dark blue with some black background. Top to bottom: Sunrise and Sunset at the top, then date on the left (preferably like Tues 3/31), and on the right a weather icon with current temp and hi/low below it in smaller lettering. Then, a 24-hour time with seconds, going completely from left to right. Underneath, I would like Altitude (left), pressure (right), below that wind (left), heart rate (right), below that humidity (left), and UV index (right). I do not want any battery life shown on the watch at all. If possible, I would like to have a weather icon that has good visuals for the different weather.
Thank you so much in advance.
Re: T-Rex 3 pro 48mm
Posted: 04 Apr 2026, 09:12
by MarioLie
If you are interested, it could look something like this, with the understanding that I will still need to create the weather.
Preview
Posted: 10 Apr 2026, 04:21
by akpinxit
Hi , added WF per your description
https://amazfitwatchfaces.com/t-rex/view/18233
Posted: 18 Apr 2026, 10:55
by MarioLie
Apologies, the weather widget took longer to create than I originally thought. Here is the watchface according to your ideas, hopefully you will like it.
Link
