Page 1 of 1
Compatibility with Sports-Tracker Heart Rate
Posted: 30 Apr 2018, 19:06
by darkliz
Hi, MiBand 2/pulse are compatible with common Bluetooth specs for Heart Rate, but Amazfit Cor seems not working. Do you expect this feature to be working when?
INFO
https://sports-tracker.helpshift.com/a/ ... le-android
Re: Compatibility with Sports-Tracker Heart Rate
Posted: 03 Sep 2018, 14:42
by darkliz
Problems with Sports-Tracker APP Bluetooth Heart-rate pairing issues (must to downgrade to work):
1. Uninstall SportsTracker
2. Downgrade SportsTracker to version 3.9.38 (find in aptoide)
3. Remove "Amazfit COR" or "Miband" bluetooth connection record
4. Make sure your "Amazfit COR" has sufficient power, and near phone, turn on restarting bluetooth
5. Make the "Amazfit COR" visible in MiFit App and try the pairing process
6. In SportsTracker app, reconfigure you Belt (heart-rate) and wait until SportTracker connects to the sensor
6a) you need to measure heart-rate in band
7. Now it's connected "Amazfit COR" heart-rate sensor with SportsTracker old version, only update to new version of SportsTracker.
Posted: 05 Jun 2020, 19:05
by savejoop
Garmin is the best smart watch for fitness tracker, I suggest you try this who are ready to beat the yesterday, and the GPS watch helps you to do perfect cardio exercise and makes you the best contestant in the games. Forerunner 935 was used to monitor your performance, training, and recovery, analyze your techniques, and follow your heart; this all features make them the best watch for fitness.
