Page 1 of 1
Watch face request [Bip 6]
Posted: 21 Dec 2025, 21:54
by Vinod123
Is it possible you could create a watch like the one i have created on Chat GPT it seems clean and modern, i would be very great full . I think the date time and day could be spaced out more evenly.
Thank you
Re: Watch face request [Bip 6]
Posted: 22 Dec 2025, 16:58
by asoo
Vinod123 wrote: 21 Dec 2025, 21:54
Thank you
Next time, if you want to specify something based on the style you attached, please include the font you used to create the image.
Since you didn't attach the file font .ttf or name of font, So I created resource from a single font similar to DigitalTime's font style. This font style will be used across all widgets.
Link to Editor and Tool
simple_watchface2.zip
(102.6 KiB) Downloaded 57 times
simple_watchface3.zip
(161.11 KiB) Downloaded 74 times
Posted: 22 Dec 2025, 18:24
by Vinod123
Thank you the layout is now perfect. Is it possible that the front could be amended to inter. Bold for time and medium for day and date. The steps, heat, time and battery are fine as is . Also when I installed it shows 24hr clock instead of am and pm. Thank you again also would it be possible to have a weather showing on the top right hand side so it would make the four corners more symmetrical? It doesn’t need to be, but if you think it would look nice, that would be good.
Posted: 22 Dec 2025, 20:48
by asoo
Vinod123 wrote: 22 Dec 2025, 18:24
The 24-hour or 12-hour time display doesn't depend on the watch face; it depends on your phone's settings. The default setting is based on your phone.
Regarding modifications, I've already stated that no further changes will be made. If you want to design it to your liking, I suggest you try doing so yourself.
Posted: 22 Dec 2025, 21:02
by Vinod123
Thank you very much I will give it a go
Posted: 29 Dec 2025, 19:00
by Vinod123
Tried and gave up : (
Posted: 29 Dec 2025, 22:45
by Vinod123
Thank you so much i see you have amended the watch face, that is very kind of you.
