Pagina 1 di 1
Apps for Mi band 10
Inviato: 10 ott 2025, 10:50
da Syed545
Can any one make apps for Mi band 10 like calculator, flappy bird and more
Re: Apps for Mi band 10
Inviato: 13 ott 2025, 07:32
da tostr
The Chinese community at BandBBS have already been making apps for the Mi Band 10 for a while now, here are a couple.
- Calculator (original post)
https://drive.google.com/file/d/1p8CzoC ... fK92xjME43
- Flappy Bird (original post)
https://drive.google.com/file/d/1NNNZ6G ... 5uGP6YdzD9
- Gallery (original post)
https://drive.google.com/drive/folders/ ... o-femx02iv
Some of them were made for the Mi Band 9, but should work perfectly fine with the Mi Band 10 if not for some scaling issues. Apps like the gallery in particular are completely in Chinese, but work fine regardless.
To install, use Notify for Xiaomi, pair your watch > update firmware > "Third party app (rpk)" and select the rpk file
Inviato: 24 ott 2025, 05:34
da Humaid
Making one app for mi band 10. Will release soon
Inviato: 14 nov 2025, 22:23
da Syed545
Thank you!
One more question. If I want to delete an app, how may I?
Inviato: 15 nov 2025, 08:38
da Humaid
Simple just install toolbox app for mi band 10. I have already released the toolbox app for mi band 10.
Inviato: 15 nov 2025, 14:21
da Syed545
Thank you!
