Pagina 1 di 1
Convert TV3 Facer to Trex Pro Watchface
Inviato: 27 set 2025, 01:46
da kifrawi
Hi @asoo ,
Need your help to port out this watchface or share the raw data. thanks
Re: Convert TV3 Facer to Trex Pro Watchface
Inviato: 27 set 2025, 02:12
da asoo
kifrawi ha scritto: 27 set 2025, 01:46
Hi @asoo ,
I'm sorry, I will not port the watch face from Fa c e . i o. I don't want to have any more problems with the owner of the watch face posted on that website.
I've already posted an announcement. You can see it here.
viewtopic.php?p=20525#p20525
Inviato: 25 ott 2025, 09:06
da asoo
If you no longer want this topic for whatever reason,
if possible, please refrain from editing the main topic by deleting topic text and posted nonsensical content.
If you really don't want this topic, you can request deletion.
Editing the head topic may cause confusion with subsequent posts.
It appears you intentionally edited your first post about requesting a watchface conversion, which maybe caused confusion in this topic. Therefore, I've removed it and restored the original topic to avoid confusion. I've also locked the thread because I believe you no longer need it, as you posted the same topic in another forum, which seems to have already helped you.
Please don't edit the Topic and first post like this again
