分页: 1 / 1
help needed to install a watchface
发表于 : 13 9月 2025, 16:39
g-rex69
Hello
i have Trex 3 and im trying to install this watchface:
https://amazfitwatchfaces.com/gtr/view/30245
Normally i can install watch faces of GTR 3 PRO on trex 3 and also i can convert watchfaces from model to model. When im trying to convert it using Watch Face Editor 14.1.1 i get a lot of errors.
Advice needed.
Thanks.
Re: help needed to install a watchface
发表于 : 13 9月 2025, 17:15
grex69 写了: 13 9月 2025, 16:39
Hello
Advice needed.
Thanks.
The creator of that watchface you mentioned has encrypted all resources, So the editor can not unpack it.
If you need to take any action, we recommend consulting owner.
In most cases, if the creator encrypts their resources, it means they don't want their work to be copied.
发表于 : 16 9月 2025, 11:37
Hello
Advice needed.
Thanks.
I've been in touch with Lars Horn and it looks doubtful that he will be update any of his watchfaces so they will work with newer Amazfit watches. He spent a lot of time developing both the watchfaces and an elaborate obfuscation technique. It does not sound like he wants to revisit these to figure out how to make them compatible with the newer ZeppOS versions.
