Page 1 of 1
Create Watchface
Posted: 07 Sep 2025, 09:51
by kifrawi
Need your help to create these watchface. Thanks a lot.
Re: Create Watchface
Posted: 07 Sep 2025, 11:44
by asoo
kifrawi wrote: 07 Sep 2025, 09:51
I think no anyone can do it for you unless you tell me which device you want to use it with.
PS:
There are many different versions of the T-rex, so you should be specific about which one you want to build.
Posted: 07 Sep 2025, 13:35
by kifrawi
For trex pro model
Posted: 07 Sep 2025, 13:52
by asoo
kifrawi wrote: 07 Sep 2025, 13:35
For trex pro model
OTH_Trex_Pro.bin
(343.08 KiB) Downloaded 57 times
