Page 1 of 1
Fix numbers resolution
Posted: 05 Sep 2025, 07:23
by SleepyHollow
Can someone help me replace these numbers with the same numbers or if possible correct them because they do not have good resolution and do not look nice on the screen. Τhe same fonts of numbers with the exact same color and size. Thank you. I attach the numbers in the file. Thank you.
Re: Fix numbers resolution
Posted: 05 Sep 2025, 08:10
by asoo
As you mentioned, the attached number images are of very poor quality.
Therefore, it would be impossible to create a quality image from them.
So, if you want quality images, I recommend that you at least know the name of the font used to create them. If you don't know, I don't think you'll be able to create a quality image. If you can, it would be very time-consuming and the resulting image wouldn't be much better.
If you don't know the name of the actual font used to create the images, I recommend asking the owner of the images you provided.
What font did they use to create the number images?
This is an image that has been enhanced 5 times over the image you provided. You can see that it is an improvement, but it is not a huge improvement and I think that is all I can do from the low quality image you provided.
Download :
TryToMake.rar
(143.24 KiB) Downloaded 54 times
Your font looks similar to MFinance HK Bold, but it's not exactly the same. If you think they're interchangeable, you can download the font and use this web tool to create your own custom number image.
or
Font MFinance HK Bold:
MFinance HK Bold.zip
(2.35 MiB) Downloaded 55 times
Posted: 05 Sep 2025, 09:38
by SleepyHollow
Thank you, asoo. You are very helpful.
