Pagina 1 di 1
Request for classic dress watchface for GTR4
Inviato: 13 ago 2025, 03:19
da Wahwah
I was looking for dress watchface style for family especial event.
I really like this watch design by Botta from Germany. I was wondering if someone can create one for GTR4. If I understand right it is 12h and 24h watch with the day of the month.
I love how simple, elegant and slim.
https://onecutreviews.com/2017/09/04/mo ... ta-design/
Re: Request for classic dress watchface for GTR4
Inviato: 14 ago 2025, 14:18
da SashaCX75
Here are some similar watch faces that I made. However, they were most likely made for a different model. But in the latest versions. In the latest versions of the editor, using resources from them, you can remake them for GTR4.
Inviato: 14 ago 2025, 15:12
da Wahwah
Thanks for your response i appreciate it, unfortunately I don’t have my personal PC to convert them but thanks for your help
Inviato: 14 ago 2025, 16:39
da SashaCX75
You can still install them. Or any of these watch faces.
https://amazfitwatchfaces.com/search/gtr/text/Botta
It's just that the size of the watch face will not match the size of the screen.
Inviato: 14 ago 2025, 16:57
da Wahwah
So I installed the one from Demiurg for GTR3 and it fits great thank you so much
Inviato: 14 ago 2025, 20:45
da Wahwah
I also installed couple of the ones you attached and they fit great thanks for that, just curious what models did you make them for?
Inviato: 14 ago 2025, 21:12
da SashaCX75
They were made for a 454*454 screen. Therefore, they should appear slightly offset from the centre on your screen.
Inviato: 14 ago 2025, 21:46
da Wahwah
I couldn’t tell that they were offset that’s why i asked
thank you sir for all the work dedicated for the amazfit community.
