Pagina 1 di 1
Display problem amazfit trex
Inviato: 08 ago 2025, 13:47
da Trex-z
Hello
After battery ended and replaced,
Watch menus and main screen appear in white boxes without graphics,
I downloaded a screen and the new screen works ok, but all menus still are as white boxes.
Attached some pictures of the problem
Any advice ?
Re: Display problem amazfit trex
Inviato: 12 ago 2025, 16:59
da taw_bip
Did you try a factory reset?
Inviato: 15 ago 2025, 14:12
da Trex-z
Yes, didn’t help
Inviato: 17 ago 2025, 21:53
da SashaCX75
How did you perform a full reset? Did you simply disconnect them from your account and reset the settings? Or did you hold down the power button while the watch was charging to roll back to the factory firmware?
When you turn on the watch, does the animation display normally, or are there problems there as well?
Inviato: 22 ago 2025, 13:24
da Trex-z
Hi
Tried both,
When charging and resetting, only small green icon appears on the screen (no charging status), please see attached photo
Many thanks 🙏🏻
