Pagina 1 di 1
Add mutiple color options to Matrix data ?
Inviato: 27 lug 2025, 10:58
da TK1
Hi All,
One of favourite Balance 2 watch faces is the Matrix data
https://amazfitwatchfaces.com/balance/view/2272
My only request is if we could have 6-7 differnce colors with the apart from the orange like in the watch facr below.. Everything else is great in that watch face..
Is something like the below possible of the Matrix data watchface ? Yellow / Red / Dark Blue / Grey / Green to go with the orange .. Is that possible ?
Re: Add mutiple color options to Matrix data ?
Inviato: 27 lug 2025, 16:44
da asoo
TK1 ha scritto: 27 lug 2025, 10:58
Hi All,
This watch face I convert will not accept any further edit requests.
- Click on number "30" to change color
Please download at the link below :
Version 2.04 for balance ( It should be work with Balance2. )
https://amazfitwatchfaces.com/balance/view/4564
Inviato: 27 lug 2025, 18:45
da TK1
Thank you mate. This is absolutely mega..
For some reason the on the AOD the minutes don't adapt to the color of the theme, month stays orange.
The rest is sooooo fking good. Thank you good sir :)
Inviato: 28 lug 2025, 02:19
da asoo
TK1 ha scritto: 27 lug 2025, 18:45
AOD will be a fixed color and will not change according to the color of the main screen.
Inviato: 28 lug 2025, 02:54
da TK1
Ohkk, I see . Thank you again for this
Inviato: 28 lug 2025, 09:38
da asoo
TK1 ha scritto: 28 lug 2025, 02:54
If you want a version where the AOD changes color according to the main page
Check out this link : https://amazfitwatchfaces.com/balance/view/4564
It's a Balance watchface but should work with Balance2
Inviato: 28 lug 2025, 19:20
da TK1
asoo ha scritto: 28 lug 2025, 09:38
This is amazing man, Thank you
The only this is ( I dont know if its a Balance 2 issue), is that in all the faces the alarm icon still remains orange for some reason ? ( 2 screenshots below) .. Rest is sooooo soooo nice
Inviato: 29 lug 2025, 01:26
da asoo
TK1 ha scritto: 28 lug 2025, 19:20
Are you using version 2.04 or are you using the version in the forum???
Because version 2.04 fixed the issue you mentioned.
But if it still doesn't work properly on balance 2, I'm not sure what the problem is, because it (version 2.04) doesn't have this problem on balance1 ZeppOS 4 and Bip6 ZeppOS 5 .
Inviato: 29 lug 2025, 04:00
da TK1
asoo ha scritto: 29 lug 2025, 01:26
whhhooo YESSS mate, downloed the new 2.04 one and its Awsome :).. its my new fav watchface now
