Page 1 of 1
Weather icons link numbers for Mi Create
Posted: 26 Jul 2025, 10:20
by screampanda
Hey guys, in need help with Mi Create software (for Mi Band 10, i think Mi Band 9 has the same number commands list) if anyone is using it please help me with the weather icons, i already design it, but when im linking the icons in the Mi Create (image list or digital number) i dont know witch number corespond to every symbol for the weather.
So if someone can write a list with each number for weather icon or someting i will be veeery grateful!
Re: Weather icons link numbers for Mi Create
Posted: 28 Jul 2025, 16:23
by krzhu
I think it will help you ;) Good luck
https://github.com/m0tral/EasyFace/wiki/Weather
I'm about to start doing this too, as I'm making a watch face for the Mi Band 10 with a popular Fallout PipBoy from MB7 :)
The worst part is that I can't find a guide for progress bars. They seem to be the hardest part because I can't seem to get them to work.
Posted: 30 Jul 2025, 11:33
by ObiJuan
I´ve created a WF with a progress bar. Let see if this can help:
Select the widget "Image list", link it to the "data source" and input in "Image count" the number of images you want to use as a progress bar.
then on every image select the image you want to use and on "index" input the min value you want to trigrer that image. for example ❤️​index 10, ❤️❤️​index 20 ❤️❤️❤️​index 30 and so on...
hope it can help
Posted: 01 Aug 2025, 10:40
by krzhu
ObiJuan wrote: 30 Jul 2025, 11:33
hope it can help
This is actually the simplest solution. I wanted a more detailed bar instead of graphics, but ultimately I used this solution from ImageList.
