Pagina 1 di 1
Unknown weather issue
Inviato: 13 mar 2025, 00:58
da piotarock
Hello developers, porters, and watchface creators,
I believe that you are all well. I have a question regarding the unknown weather image. Sometimes, when it rains the watchfaces (including the ones from Zepp) show 'unknown weather'. However, the watchfaces by mirda69 always indicate 'rain'. I unpacked his watchfaces and found out that he doesn't include the unknown weather image icon. Now, here's my question, is it okay to neglect the unknown weather and replace it with rainy weather icon?
Kind regards,
piOtarOck.
Re: Unknown weather issue
Inviato: 13 mar 2025, 02:56
da asoo
piotarock ha scritto: 13 mar 2025, 00:58
Kind regards,
piOtarOck.
The screen shows UNKNOW, it means that at that time zepp may not have received the weather data sent from the weather server for some reason.
When zepp sends that data to the watch, the watchface shows the unknow icon.
In my opinion, I think it is up to the creator to decide. If you think it is OK, you can replace any weather icon instead of unknow.
But it must comply with the index requirements set by zeppOS.
https://docs.zepp.com/docs/reference/de ... ht=weather
Inviato: 13 mar 2025, 12:33
da SashaCX75
I think it's more correct to write to Amazfit support to have them fix this issue.
This may be a temporary solution for now. But you have to decide what is better for you: sometimes showing unknown weather instead of rain or sometimes showing rain instead of unknown weather. Personally, I've only had this problem once in the whole time. So I use the standard set of weather icons.
Inviato: 14 mar 2025, 02:56
da piotarock
Thank you very much for your responses @asoo and @SashaCX75.
