Page 1 of 1
Can you make it work my pointer with the color ?
Posted: 12 Feb 2025, 10:00
by rush2112
Hello @asoo ,
I'm having difficulty getting the color to work properly on my GTR3 Pro. The issue seems to be that the pointer is not aligning with the selected color. No matter what color I choose, the pointer does not change accordingly. Can you provide guidance on how to resolve this issue?
Thank you!
ss_infometer_vi-642201-c0755c7ae6.zip
(407.61 KiB) Downloaded 82 times
Re: Can you make it work my pointer with the color ?
Posted: 12 Feb 2025, 11:15
by asoo
rush2112 wrote: 12 Feb 2025, 10:00
Hello @asoo ,
Thank you!
From checking, it seems that you did not use the script I did to create the dial, but you used the ability to click to change the Backgorund in the editor to create it. If that's the case, you would not be able to manage in the step pointer element change section, because the editor does not have that section.
So if you want to change the color of the step pointer, you can do it in 2 ways:
1. Use a custom script to manage it.
2. Insert the script in the original script that the editor created. ( in index.js )
In this case, I will do the second way to give you an example.
By inserting a script to toggle the step pointer, using the variable "backgroundindex" in the Change background section as the handler to change the color order of step pointer.
normal_step_pointer_progress_img_pointer.setProperty(hmUI.prop.MORE, {
src: "Pointer" + parseInt(backgroundIndex + 1) + ".png",
center_x: 240,
center_y: 240,
x: 10,
y: 238,
start_angle: 270,
end_angle: 379,
invalid_visible: false,
type: hmUI.data_type.STEP,
Insert this script into the
- switchBackground() function
- //SwitchBackground
in index.js that created by the editor.
This is an example of a watch face that does the insert script to change the step pointer color.
ss_infometer_vi-GTR3PRO.zip
(407.66 KiB) Downloaded 82 times
Posted: 12 Feb 2025, 22:12
by rush2112
Thank you so much for generously sharing your time with me. I truly appreciate it! I look forward to delving into this more deeply over the weekend.
Marc ( Rush 2112 )
