How install custom watchfaces to Balance
Posted: 09 Nov 2024, 09:25
Hello to all. Please can someone help me how i can install custom watchfaces on balance. Thank you.
Community
https://amazfitwatchfaces.com/forum/
Have you tried using our app, which allows installation via QR code? It should simplify the process for you on the Balance. Let us know if you need further guidance!amazfitfacesafrica wrote: 09 Nov 2024, 09:25Hello to all. Please can someone help me how i can install custom watchfaces on balance. Thank you.
The QR code should actually appear on your watch screen, and then you scan it with your phone using the Zepp app in developer mode. This way, you don’t need an extra screen!amazfitfacesafrica wrote: 09 Nov 2024, 09:45Thank you for reply. Finally i found way with installation via QR code. Is there way solution to install watchface with file and not with qr code because i must have another screen to scan qr code. Thank you. And i found that city name not display in my watch why?
On my T-Rex 2, I am on Android. I download the .zip file from the site with the mobile browser then use the "Notify for Amazfit" to install by browsing to the downloads folder.amazfitfacesafrica wrote: 09 Nov 2024, 09:25Hello to all. Please can someone help me how i can install custom watchfaces on balance. Thank you.
Can you please tell me how do you install zip file watch faces using the Notify for amazfit app?taw_bip wrote: 14 Nov 2024, 12:46On my T-Rex 2, I am on Android. I download the .zip file from the site with the mobile browser then use the "Notify for Amazfit" to install by browsing to the downloads folder.amazfitfacesafrica wrote: 09 Nov 2024, 09:25Hello to all. Please can someone help me how i can install custom watchfaces on balance. Thank you.
I used to be able to install by sharing the file to the Amazfitwatchfaces app but that no longer works.
I install watchfaces from my Android phone this way:al0o0z wrote: 22 Nov 2025, 01:45Can you please tell me how do you install zip file watch faces using the Notify for amazfit app?taw_bip wrote: 14 Nov 2024, 12:46On my T-Rex 2, I am on Android. I download the .zip file from the site with the mobile browser then use the "Notify for Amazfit" to install by browsing to the downloads folder.amazfitfacesafrica wrote: 09 Nov 2024, 09:25Hello to all. Please can someone help me how i can install custom watchfaces on balance. Thank you.
