Pagina 1 di 1
Port out: Facer to T-rex Pro
Inviato: 28 lug 2024, 02:26
da kifrawi
Hi All,
Please port out these watchface. Thanks.
https://www.facer.io/watchface/MnctlLBr ... axyactive2
Re: Port out: Facer to T-rex Pro
Inviato: 28 lug 2024, 03:42
da asoo
kifrawi ha scritto: 28 lug 2024, 02:26
Hi All,
If I remember correctly, TrexPro does not support Animation.
So I think it is unlikely that this dial can be made for TrexPro like the original.
I have seen your previous work and I think you can make this dial, if you have the dial resource, I have collected the dial resource in the attached file. I hope it will be useful for you.
only resource Not Watchface:
resource_Tetris.rar
(904.78 KiB) Scaricato 97 volte
