Página 1 de 1
Faces for GT3 pro
Enviado: 19 Jun 2024, 08:59
por bennyrusso87
Hello everyone. I have a GT3 Pro. What are the compatible faces of other watches with my GT3 Pro? or can I only use the ones created for it?
Re: Faces for GT3 pro
Enviado: 19 Jun 2024, 12:54
por asoo
Because you are posting a question in the Amazfit Forum. First of all, I would like to ask you that.
Do you mean Amazfit GTR3Pro or Huawei GT3 Pro?
If you mean the GTR3Pro, I have some observations as below. But if you mean
Huawei GT3 Pro I don't have any information on this matter. I recommend posting an inquiry in the Forum.
viewforum.php?f=137
---------------------------- Amazfit GTR3 PRO ---------------------------------------------------------
The dial that can be use 100% on GTR3pro is only GTR3 because both use ZeppOS 1.0, but the size of the dial will not be correct because
The GTR3 has a screen size of 454x454 while the GTR3pro has a screen size of 480x480.
There will be an Amazfit Balance watch face with the same size as the GTR3pro, but the zeppOS used will be different. The Balance uses zeppOS 3.5, so only some watch faces can be enabled with the GTR3pro, but not all watch faces will work properly. If any watch face uses a command set that is not supported by ZeppOS 1.0, that watch face will not work properly.
Actually, some zeppOS 2- 3.5 watch faces can be opened on the GTR3pro. If the watch face does not use a command set that exceeds ZeppOS 1.0 support
However, if you want it to work properly It must be recommended to use according to your model.
P.S.
Some ZeppOS-based watch faces can be converted for use with the GTR3Pro.
ิBy using the program "Watch face editor for Amazfit watch on ZeppOS"
It helps in converting. However, the dial that is converted must comply with the program's standards and after converting, some elements may look different or be unusable. Due to differences in ZeppOS
