Page 1 of 1
Nuevo GTS watchface for GTS 4
Posted: 08 Apr 2024, 15:01
by Pe86Hpsi
Re: Nuevo GTS watchface for GTS 4
Posted: 08 Apr 2024, 16:10
by asoo
If you mean the dial, follow the link below.
https://amazfitwatchfaces.com/gts/view/2918
I recommend asking permission from the owner of my work first because the owner of the work has already stated in the description that " NO SE ADMITEN COPIAS, VERSIONES, O MODIFICACIONES ".
And the dial is a "Verified watch face" type watchfacde.
which has the following requirements
Verified watch face - works marked with a special sticker and have several advantages:
Copying or modifying works marked with a special sticker is possible only by agreement with the author.
In the case of unauthorized copying, the Verified watch face author has the right to make a complaint, and the website's administration will immediately remove the modification or copy of his/her work.
Therefore, it is recommended to request permission from the owner of the work to adapt their work or contact the owner of the work to proceed with your request. It is best.
Posted: 08 Apr 2024, 16:37
by Pe86Hpsi
Ok Thanks i want it not for sale not for upload but for personal use
Posted: 08 Apr 2024, 17:44
by asoo
I thought you were going to sell it or not? That is not an important issue.
What I want to say is The owner doesn't allow to modified
If you want to modify I only recommend that you contact the author of the work. to respect the work he has done.
If someone helps you convert this watchface. However, It must be uploaded in this topic which is public and if you do not have permission from the author of the work. The person who is blamed is the person who helped you.
