Page 1 of 1
Watchface Maker not loading
Posted: 03 Mar 2024, 01:48
by Emiliomc
Do you know if there is any problem with Watchface Maker? "Authorizing" appears in the web address and I cannot enter.
Re: Watchface Maker not loading
Posted: 03 Mar 2024, 02:50
by asoo
Emiliomc wrote: 03 Mar 2024, 01:48
I'm not sure if you're talking about zepp's Watchface Maker ( https://watchface.zepp.com ).
If yes, I have tested it. I can access it normally.
PS. To use WatchMaker, you must register with the web first. But if you register has been completed and cannot log in. I am not sure of this problem that you found too.
Posted: 03 Mar 2024, 03:13
by Emiliomc
Well it doesn't load. neither before login nor after. only appears authorized in
Posted: 03 Mar 2024, 07:47
by asoo
Emiliomc wrote: 03 Mar 2024, 03:13
I'm also not sure what the reason for your problem is. I tested it and it still works fine.
It may be in your browser. Try changing it or try clearing your browser's cache.
I used to be unable to log in. I tried clearing the cache and was able to continue using it normally. However I've never encountered a problem like the one you've described.
Posted: 03 Mar 2024, 10:42
by Emiliomc
Thanks for trying to help me. I use Chrome. It worked perfectly with this browser. And suddenly one day the Watchface Maker website appeared with "Authorization". Still the same. I have cleared chrome cache, but it's still the same. And I wouldn't want to change browsers, since Chrome is the one I like the most.
Posted: 03 Mar 2024, 10:54
by Emiliomc
Sorry, I forgot it. If I log in, I have the logout option. When I enter it stays on "Authorizing". And I can only enter Upload for Approval, Help and Feedback. But I can't enter Create, nor My Watch Face.
This is really what happens. I explained myself wrong before.
Posted: 03 Mar 2024, 11:04
by Emiliomc
I checked out zepp-health (githup.com) and it seems to be a recent issue. They will report to the cloud team first thing Monday morning.
