分页: 1 / 1
editable elements and moon phase
发表于 : 15 2月 2024, 10:07
Rafi87
Hello
I have a GTR 4 LE
I'm trying to add the moon phase to my watch face, but it doesn't work, the moon phase is always extended by one day, as the full moon shows two days in a row and it no longer comes out according to the date
I use Amazfit_Watch_Face_Editor_(ZeppOS)
I would like to try the editable elements, but I don't know how to do it, I don't know how it works, can someone describe it to me, or even better, add screenshots so I can see it?
thank you in advance for your help
Re: editable elements and moon phase
发表于 : 15 2月 2024, 10:41
Rafi87 写了: 15 2月 2024, 10:07
Hello
I have a GTR 4 LE
@Rafi87
I suspect that the moon phase display you mentioned may be due to
1. Images used or the number of images used. Data from Zepp web has shown images and the number of images of the waxing and waning moon at 30 images according to the link below.
https://docs.zepp.com/docs/designs/cust ... se#weather
2. Or it may be caused by FW (if this is the case it will be difficult to fix)
3. Or Information sent from the server of the weather service provider. In this part, as far as I have ever encountered, sometimes the server does not update the information, which may cause the display to be incorrect.
However, as far as I can observe, the display on Amazfit Balance seems to display correctly (using 30 images).
Hope the information is useful to you.
发表于 : 15 2月 2024, 11:39
Rafi87
Hi
I used 15 images of the moon and have not yet installed them in the watch
I tried the moon phase only in the program, from SashaCX75, in which I create a watch face and I compared it with the calendar, the moon phase and the full moon show me twice and then it doesn't work anymore
as for the editable elements, how can I set it?
I would like to change the moon phase, sunrise and sunset and UV index
发表于 : 15 2月 2024, 12:51
Rafi87 写了: 15 2月 2024, 11:39
Hi
"editable elements"
As for "editable elements" I can't explain.
Because I haven't used it for a long time. I use a custom script to handle this part.
But as far as I can remember, the steps
1. add zone
2. Add element that will be in that zone.
As for making images to display zones, you'll have to test it yourself. I can't remember the order.
发表于 : 15 2月 2024, 17:04
Rafi87
alright
thanks for the advice, I'll try it
