Pagina 1 di 1
RZ250_Mod Lattenknaller
Inviato: 13 feb 2024, 11:54
da amazfitfacesafrica
Hello to all. Can anyone with knowledge help me and convert this watchface for GTR3 Pro because sasha editor 10.3 can't convert it properly. If it's possible replace altitude because GTR3 Pro don't support it with barometer or whatever can GTR3 Pro show or take off altitude completely. I think it's a complex watchface for me. Thank you and a big thanks to Lattenknaller for the amazing dials he creates.
https://amazfitwatchfaces.com/balance/view/207
Re: RZ250_Mod Lattenknaller
Inviato: 14 feb 2024, 07:24
Good morning to all. Please someone to help me. Thank you.
Inviato: 14 feb 2024, 09:44
da asoo
amazfitfacesafrica ha scritto: 13 feb 2024, 11:54
First of all, let's point out the following: Editor 10.3 can convert this watch face correctly, but because this watch face is from Balance which uses ZeppOS 3.0 which has the ability to display letters. can be customized according to the specified angle, but in GTR3pro ZeppOS 1.0 does not support such display, so when converting, the display of letters according to the angle can only be displayed normally.
If desired, edit this section. Can be done in about 3 ways.
1. Design multi-level font images and use "sapcing" to help display
2. Writing a script to display the obtained values at the specified angles. The same applies to the display of "steps" in the "Value at angle" category, in which case many elements in the editor do not provide this. If you have to, you'll have to custom script yourself.
3. Design a completely new layout for elements that use angle comes as a normal text display
All 3 types are probably not easy to do. I'm only here to provide information. I hope that other people who are interested in this watch face who use ZeppOS 1.0 will be able to use it as information to edit themselves.
Inviato: 14 feb 2024, 09:52
Thank you for info, asoo. As i said this watchface is too complex for me right now because I am amateur yet. Thank you anyway for all your help to us.
