Pagina 1 di 1
HK95 by SmaWatch - Watchfaces
Inviato: 11 feb 2024, 22:39
da MaddieM
Am08 HK95 by SmaWatch with Amoled 410x502px resolution using CoFit / Smart-Time Pro etc
https://www.smawatch.com/Home
I have included a premade Watchface from the CoFit app for HK95 model so that one of you guys can check it out and see if it's in any recognizable format that has any program available for it.
https://api.iot-solution.net/
Researched the topic enough to understand that different manufacturers use different whatchface formats even though on the surface, they all seem like the same thing.
These are some of the premade wf's available in the app, and they are all accessible by going to android>data>cofitapp>cache>dials folder on your phone using a file explorer .
I am interested in the format used for the watchfaces on this model, as well as the procedure of transferring custom made wf's onto the watch.
