Problem Watchface Maker GTS 4 area size
Додано: 27 листопада 2023, 01:01
I have a problem with Watchface Maker when creating watchfaces for GTS 4. For example, to create a digital clock from the right of the screen on a Bip U Pro we have the coordinates, the area size and the alignment. However, to create a digital clock for a GTS 4 there is no area size, but rather a blue rectangle.
I always create the digit 1 in .png with less width than the rest of the numbers because otherwise all the double numbers that go with 1 are very separated (1 1, 2 1, etc).
With the possibility that does exist for the Bip U Pro with the area size, there is no problem having the number 1 smaller in width, but when I create a watchface for the GTS 4, the time moves to the left if it reads, for example, 11:21 . I clarify that in both cases I put the alignment on the right, of course.
That is, in the case of the creation of the Bip U Pro the example at 11:21 does not move to the left. It stays to the right, but the time is obviously displayed less wide.
I hope I have explained myself well to see if you can help me. And let's see if the translator doesn't do it wrong.
