Сторінка 1 з 1
Zepp Watchface Editor not running (GTS 2 mini)
Додано: 13 квітня 2023, 20:53
joel43
Hi all,
I have been searching for an answer to this but no one seems to know.
I have an amazfit GTS 2 mini and made a custom watch face on www.watchface.zepp.com however, when I press "Run on device" and scan the QR code, my Zepp app says "An Error occured. Please try again later. Watch face does not support bound device."
Firstly, is there a simple thing I am doing wrong or is there something wrong with the editor?
Secondly, if the editor doesn't work, is there any other way I can get this to run on my gts 2 mini (eg: using a .zab file?). I have tried exporting as .zab and replacing a .bin watchface in the files on my phone with the new one (viewtopic.php?f=14&t=783) but I have Android 11 and the .bin file just isn't there.
Please could someone help as I am getting frustrated! :x
Thanks in advance,
Joel43
Re: Zepp Watchface Editor not running (GTS 2 mini)
Додано: 21 травня 2023, 09:16
minixperia
When you export the .zab, you need to open the .zab as a .zip, then open the .zip inside and extract the source.bin that you find inside it and put it where you want,
then you can put the source.bin on the phone memory,
Install the amazfit whatchfaces app,
then you go in the .bin file and it will opened with the amazfitwhatchface app to charge it on the smartwatch,
but beefore you charge it you need to remove one watchface from the smartwach because it not overwrite autimatically the watchfaes...
Ps. in the official zepp whatchface editor digital clock not work.
PS... Ps...
if you want another tool i use this find on github
https://github.com/JulienMaille/py_amaz ... ree/master
