Page 1 of 1
overlapping elements
Posted: 29 Dec 2022, 21:44
by GatoChillX
hello, how can you order the overlapping of the elements, I want to put the battery under the text of the battery but the battery overlaps
the text does not go there but the image of the battery is above
Re: overlapping elements
Posted: 19 Mar 2023, 10:23
by itaketapps
Unfortunately, there is no way to change the display order of the elements, but the order of the "layers" of the elements itself. I can recommend you to draw the battery icon in a less red color, then the text will be visible.
https://amazfitwatchfaces.com/mi-band-6/view/3992 - here is my work for an example.
