Page 1 of 1
Port watchface GTR3 pro
Posted: 13 Oct 2022, 09:57
by SleepyHollow
Hello to forum, can anyone helpme and port this watchface for GTR3 Pro in blue cyan like photo and is welcome any ideas for this watcface. Thank you for support.
Re: Port watchface GTR3 pro
Posted: 14 Oct 2022, 08:41
by asoo
SleepyHollow wrote: 13 Oct 2022, 09:57
Image Image
Normal :
KD-Big_GTR_3_Pro.zip
(291.71 KiB) Downloaded 94 times
Can change color same as GTR3 Version
https://amazfitwatchfaces.com/gtr/view/28311
KD_Circle_click_MOD_FBWAOD_GTR_3_Pro.zip
(357.17 KiB) Downloaded 141 times
note :
Posted: 14 Oct 2022, 09:40
by SleepyHollow
Thank you so much, it's perfect but i attach a photo to see 2 lines behind digital hour numbers and in the middle of hour and minutes. In the preview here there are no lines. Can fix it? May I ask a question? It is difficult for someone to add other colors with the wax code like your and wax watchfaces? Thank you.
Posted: 14 Oct 2022, 10:10
by asoo
SleepyHollow wrote: 14 Oct 2022, 09:40
I am not sure , I can fix it or not , Because this issue must be tested on real device.
in the editor displayed correctly.
however I've tried increasing the black border size but not sure if that fixes the problem. If the fix does not resolve the issue You must try it yourself.
You can download again
viewtopic.php?p=13974#p13974
Posted: 14 Oct 2022, 10:22
by SleepyHollow
You are awesome, it's fixed. Thank you again.
Posted: 14 Oct 2022, 11:17
by SleepyHollow
Is it possible to convert your GTR3 version for GTR3 pro?
Posted: 14 Oct 2022, 12:16
by asoo
SleepyHollow wrote: 14 Oct 2022, 11:17
I can convert to GTR3pro But after convert, if the display is not correct same preview , I will not fix it, because I don't have GTR3pro to test. and have many element must to test on real device. If you agree as I described I will convert for you
Posted: 14 Oct 2022, 12:19
by SleepyHollow
Yes of course. Thank you so much.
Posted: 14 Oct 2022, 12:32
by asoo
asoo wrote: 14 Oct 2022, 12:16
SleepyHollow wrote: 14 Oct 2022, 12:19
You can download in here :
Posted: 14 Oct 2022, 12:34
by SleepyHollow
Thank you so much, i test it and it's ok as the preview. Have a nice weekend.
