Página 1 de 1
Add an aod [GTS 2 mini]
Publicado: 20 Jul 2022, 05:18
por philmangest
Can somebody help add an aod for this watch face
https://amazfitwatchfaces.com/gts/view/5400
Re: Add an aod [GTS 2 mini]
Publicado: 20 Jul 2022, 09:59
por asoo
I am not sure this BIN work or not. I can not test because i don't have GTS2Mini
In editor it can add AOD only Day , week , Analog hour+min. Other AOD function in editor after add other AOD element. That function not create on json file.
If you want to try to edit or modify. You can found other tool in this post :
viewtopic.php?p=12537#p12537
Note :
- Use a third-party editor to edit.
-Next time, if who want to request edited the watchface . That posted on this web. I recommend asking permission from the owner of the work first.
Publicado: 21 Jul 2022, 02:21
por philmangest
Thank you for the info
