Pagina 1 di 1
Mods don’t approve watchfaces?
Inviato: 20 giu 2022, 15:30
da jakubgaluszka
I’m used to converting faces from gtr 3 pro to GTR3 and upload them for me and others
Always worked, but suddenly no watchfaces gets uploaded… always in mod status and then they disappear
No explanation. Doing it in same way as always.
Re: Mods don’t approve watchfaces?
Inviato: 20 giu 2022, 16:30
da asoo
What program you use to convert GTR3pro to GTR3 ?
if you use " Amazfit GT3 Series Watch Face Editor (GTR 3, GTR 3 Pro, GTS 3) " to convert.
The watchface you bring to convert must to use .js script in version 1 and all element use to built watchface . The program must be have that element.
Now some watchface is built for use .js script Version 2.0 from web ( zepp watchface maker )
Program" Amazfit GT3 Series Watch Face Editor (GTR 3, GTR 3 Pro, GTS 3) " can not convert that watchface.
Inviato: 20 giu 2022, 16:44
da jakubgaluszka
Oh, and is there any other simple program to convert them? It was super easy with couple clicks. Thanks
Inviato: 21 giu 2022, 08:04
da jakubgaluszka
asoo ha scritto: 20 giu 2022, 16:30
Went thru post on these forums, but couldnt really find any other way to convert them...
Inviato: 21 giu 2022, 08:19
da asoo
At the moment, the way to bring the Watchface that uses Script JS Version 2 to modify.
You must bring the images resource of the watchface you want modify , and bring it to built a new one on the program editor only.
Program convert images GT format to normal PNG ( By
SashaCX75 )
https://github.com/SashaCX75/ImageToGTR3/releases
Inviato: 21 giu 2022, 09:30
da jakubgaluszka
asoo ha scritto: 21 giu 2022, 08:19
SashaCX75 )
Thanks, i also just find out i can convert it and upload it as private and it worked on my GTR3... So whats the problem?
I can upload it, download it and use it, but it cannot be uploaded for others, can it cause some issues? Thanks
Inviato: 21 giu 2022, 11:33
da asoo
I am not sure , your question.
Let's say that if the watchface you used to conver is a file that uses scrip Version 1, then you can conver and use it normally.
But if the file uses scrip Version 2 to create, you will not be able to conver with " Amazfit GT3 Series Watch Face Editor (GTR 3, GTR 3 Pro, GTS 3) " program.
If possible it would be nice to specify the watchface you are talk about it , so that it will be easy for answer questions.
In the upload section on the web if you can upload and download it to use on your watch. I think there shouldn't be any problem in using it by other.
Inviato: 21 giu 2022, 11:56
da jakubgaluszka
For example this one :
https://amazfitwatchfaces.com/gtr/view/24898
Example 1 and 2:
1) I converted it via Amazfit GT3 Series Watch Face Editor and upload it on page. It was not allowed and it never showed in GTR3 category (mods delete it i guess)
2) I converted it via Amazfit GT3 Series Watch Face Editor and upload it on page as private watch face and i can now download it on my phone via app to my GTR3
For some reason it was never accepted by mods (tried it 2 times) but its fine and its working when i post it as private upload.
Inviato: 21 giu 2022, 12:38
da asoo
In this case I am unable to verify.
We recommend that you inquire with admin.
Inviato: 21 giu 2022, 14:10
da Drongo
jakubgaluszka ha scritto: 21 giu 2022, 11:56
Example 1 and 2:
Hello.
Your work was rejected due to violation of the rules of the site in the "Description" section.
"The description box is required and must contain as detailed information as possible about the uploaded watch face (version description, style, color, theme, etc.)."
Inviato: 22 giu 2022, 05:44
da jakubgaluszka
Drongo ha scritto: 21 giu 2022, 14:10
Example 1 and 2:
Hello.
Oh, thanks for information. I will then reupload and provide more details
