Page 1 of 1
Can someone make this watchface [GTR3 PRO]
Posted: 21 Nov 2021, 05:41
by whdud124578
Re: Can someone make this watchface [GTR3 PRO]
Posted: 04 Dec 2021, 09:39
by asoo
Thank "iamlabovic" for this watchface in 47mm version
https://amazfitwatchfaces.com/gtr/view/12445
Pipboy Orange
Only GTR3 Version it's tested on real device ,
GTR3pro Version not test on real device because I do not have GTR3Pro.
PIPBoyGTR3Pro.zip
(398.48 KiB) Downloaded 167 times
PIPBoyGTR3.zip
(346.42 KiB) Downloaded 167 times
Posted: 04 Dec 2021, 17:06
by phoenix1988
Once again, many thanks from Russia. The dial is good. the distance is cut off a little, but this is not critical.
Posted: 28 Jan 2022, 22:02
by jorixine
hey!
I am using this one and after the firmware update from today... its showing the little hands in the shortcuts... any idea what could changed to get this behavior now ?
Posted: 29 Jan 2022, 15:51
by asoo
?? Are you using the file I made ??
If so, there shouldn't be a picture of a small hand.
Because the ones contained in this Topic don't have shortcuts area.
Posted: 31 Jan 2022, 12:45
by jorixine
hey asoo, I grabbed this one and made some changes... but its weird because I used the green one too. Both have the same mods and one works and the other does this strange thing.
I'll take a look at the code to see if I find any difference.
Posted: 31 Jan 2022, 13:08
by asoo
jorixine wrote: 31 Jan 2022, 12:45
you can fix by make image for shortcut is empty Transparency image.
Posted: 20 Feb 2022, 13:59
by jorixine
that's what I did! thanks!
