Page 1 of 1
Dual time zone watch face
Posted: 22 Aug 2021, 13:48
by xeno
Hi, is it possible to create a watch face with 2 digital time zone : GMT and GMT+5:30. If possible please make one. Thanks
Re: Dual time zone watch face
Posted: 22 Aug 2021, 15:46
by wichr
Are you sure you need GMT and GMT+5:30? Not GMT and GMT+5:00 or GMT and GMT+6:00?
Posted: 22 Aug 2021, 18:10
by xeno
Hi Wichr, thanks for asking. My local time is UTC+5:30 and I need the UTC time as well. KLINHA has already made one watch face but it has digital local time and analog GMT. So wanted to know whether it's possible to have a watch face with both the times digital. Thank you.
Posted: 23 Aug 2021, 06:41
by wichr
Yes, its possible. The watch does not support that function natively, but as a workaround we could use double ciphers which display the targeted time zones at the same time. Even triple time zones or more are possible that way.
The downsides of that workaround are, that the targeted time zones need to be known at design time, and that we need to redesign and repack the wf in order to change them afterwards.
Do you have a wf in mind, that you would like to display multiple time zones?
Posted: 23 Aug 2021, 09:46
by xeno
Thank you Wichr, I don't have any WF preference. You can use one of your favourites. Local time (GMT+5:30) in analog and GMT in digital will be better I think. Thanks a lot for helping.
Posted: 23 Aug 2021, 12:13
by wichr
Displaying local time in analog and GMT in digital form is another faisible option. But I am not sure if I can help you further than that, because you did not yet mention what watch the wf is for, and I do only create wfs for GTR2 and GTS2e, which are the watches I have access to, for testing purposes.
Posted: 23 Aug 2021, 12:24
by wichr
Looks like you need a wf for the GTR 47mm, since this seems to be the watch targeted by KLINHA.
I do have access to the required toolset to create a wf for that watch, but I would deliver it without any warranty, because I do not have access to that watch for testing purposes. In addition, I really would like you to designate a wf design as template, because my choice would possibly really not fit your taste.
Posted: 23 Aug 2021, 13:28
by xeno
Hi Wichr, I want the WF for GTR2. I will share the WF after taking permission from the creator.
Posted: 23 Aug 2021, 14:11
by xeno
Hi Wichr, you can use the WF you have created. https://amazfitwatchfaces.com/gtr/view/17145.
Try to make the font yellow. Thanks in advance.
Posted: 23 Aug 2021, 16:26
by wichr
After rethinking on the subject I realized that you need to set your watch to GMT, if you want it to display the GMT on a digital face and the local time on an analog one, because the digital face can't be tricked to show an offset (see explanation below). But that would make your watch showing the wrong date between 00:00h and 05:30h.
The other way around (showing local time on a digital face and GMT on an analog face) would work with the watch set to GMT+5:30, because we can rotate the analog hands in any angle and direction without the watch noticing.
Explanation: Setting an offset won't work, because internally the watch uses a set of pairs of identical digits (one pair for the hours, one pair for the minutes and one pair for the seconds) and we cannot make the watch apply a different offset for each of the two digits of a pair.
Example: Let's say, we add an offset of 3, in an attempt to make the watch display 12:30 instead of 12:00 on the digital face. Then the clock would display 12:33, because it won't use different offsets for the two digits of the minutes pair. The same goes for the hours and seconds digits, of course.
To make it short, KLINHA adopted the only elegant solution for showing two time zones on one wf: Displaying the set time on the digital face and the offset on the analog one.
So, if your'e still interested, I'll add a variant of my wf with an offset of -5:30h on the analog face.
I'm sorry that I did not realize that earlier.
Posted: 23 Aug 2021, 17:53
by wichr
Here we go
[removed, because the hour hand pointed half an hour next to the actual time]
Posted: 23 Aug 2021, 18:27
by wichr
well... not yet. Please stand by, the hour hand needs a shift of about half an hour.
Posted: 23 Aug 2021, 18:33
by wichr
This time it's for real:
[still not]
Posted: 23 Aug 2021, 18:34
by xeno
Hi Wichr. There is nothing to be sorry about. Thank you very much for sparing so much time to answer my request and providing an in-depth explanation. Really appreciate your time and effort.
Posted: 23 Aug 2021, 18:50
by wichr
Your'e welcome. This wasn't a big deal, really. The fact that you chose my wf reduced the effort a lot.
Posted: 23 Aug 2021, 18:52
by wichr
Btw, what was that request about yellow font? Isn't the original font yellowish enough? Or do you prefer an other temperature? Maybe more aggressive?
Posted: 23 Aug 2021, 18:55
by asoo
wichr wrote: 23 Aug 2021, 18:33
https://amazfitwatchfaces.com/gtr/view/17186
I think hands clock in AOD mode not correct
Posted: 23 Aug 2021, 19:00
by wichr
You're right. I forgot to apply the correction on the AOD screen. Will provide the correction on the AOD screen in a few minutes.
Posted: 23 Aug 2021, 19:10
by wichr
Done :-)
Posted: 23 Aug 2021, 19:11
by xeno
wichr wrote: 23 Aug 2021, 18:52
It's ok. The font change is no longer required as we are not using digital for GMT. With AOD no further changes required. It solved my purpose 😊.
Posted: 23 Aug 2021, 19:12
by wichr
Big fan of your great work says Hi asoo
Posted: 23 Aug 2021, 19:14
by xeno
Me too.
Posted: 23 Aug 2021, 19:33
by wichr
Posted: 24 Aug 2021, 04:45
by xeno
Very happy to see good number of downloads for your new watch face.🙂
Posted: 24 Aug 2021, 05:20
by wichr
Well, I hope they are aware that this wf displays two different time zones. I have mentioned that in the description, but I think not everyone reads the description before they install the wf.
I rellay like the hands glowing red, like if they were extremely hot. That looks gorgeous and fits really good to the background. Thank you for that idea. I'll try to use that set of colors (but with a slightly more comic-style yellow) for my next wf.
