Page 1 of 1
Port Request from Bip to Bip S
Posted: 26 May 2021, 16:36
by Ursalla
Hi all,
in the meantime I found the link to my favorite watchface on BIP...
I would like to have it on BIP S as well, and if possible with German weekdays.
Can you help?
The original watchface is
https://amazfitwatchfaces.com/do/dl?dir ... 3438&d=bip
Main page of WF : https://amazfitwatchfaces.com/bip/view/13438
(should be the English version with 24h time and European date)
Many thanks Ursalla
Re: Port Request from Bip to Bip S
Posted: 27 May 2021, 16:47
by WilomanCZ
Ursalla wrote: 26 May 2021, 16:36
Hello i remaked it for you. Enjoy it. :)
Posted: 27 May 2021, 19:14
by Ursalla
Hi Wiloman,
You are the best! Thanks a lot.
I had some issues to install it via Notity, but finally it worked!
Everything works fine, except the grafical bar of the battery measurement. It always shows red/ almost empty. But this is minor minor for me, the number aside is correct.
I assume, the use of German workdays (Monday=Montag etc.) is too difficult to change!?
Thanks again, and have a good evening!
Regards from Nuremberg area
Ursalla
Posted: 28 May 2021, 03:05
by WilomanCZ
Ursalla wrote: 27 May 2021, 19:14
Hi Wiloman,
Ursalla
Hello, battery bug is fixed now. (Bip_S support only 6parts for my compilator.)
Posted: 28 May 2021, 07:26
by Ursalla
Thanks again! It is perfect now!!
