Page 1 of 1
12/24 Hour Time [Amazfit X]
Posted: 13 Feb 2021, 20:39
by lynnux
I really like some of the custom watchfaces you all are posting for the X. Some of my favorites seem to be usable only in 24-hour time, and can't be switched to 12-hr time, which is what I'm used to. Is there a way to switch to 12-hr time that I'm not aware of? (My system time is always 12-hr). Would it be easy for the creators to share a 12-hr version in addition to the 24-hr one?
One option would be for me to download the watchface program, and modify some of the custom faces myself - I may do this if there aren't other options.
Many thanks to those creating new watchfaces for this device!
Re: 12/24 Hour Time
Posted: 15 Feb 2021, 15:07
by Inquisitom
Hello, thanks for the feedback.
For your info, I tried updating some of my watchfaces for 12hr but there's a bug in the firmware. If you select 12h format, the sunrise & sunset values will appear as null. I cannot even have them being displayed in the weather section of the watch.
Is this the same for you ?
Re: 12/24 Hour Time
Posted: 18 Feb 2021, 00:25
by lynnux
I haven't downloaded any custom faces that allow switching between 12/24 hr, so I can't answer this.
